- 12,195
- 326
- 0
- gainesville, ga.
If the gear box is fill or mixed with hyd. oil, or leaking everywhere, the piston/cylinder assembly needs to be rebuilt or replaced, the output shaft seal is bad and forcing oil into the gear box.the gear box takes gear oil, 1" below fill plug, we used hyd. oil, it is the same as 10wt, but has anti foam and anti corrosion additives for the steering reservoir, I would never run atf in a hyd. system.
