Intercoolers by themselves really don't make much power
That is a good point. You could even go farther and say you
lose power because a cooler intake charge will lower both boost and the combustion temp. Lower combustion temp will reduce the force pushing on the piston...
The lower the EGT may in turn reduce turbine speed lowering boost even more....
You could even go farther and say less power will also take a load of the engine cooling system which may lower coolant temp a fracton of a degree or two. Heat loss to cooler cylinder walls will lower pressure ...and the push on the piston
Cooler pistons contract lowering chamber volume and static compression ratio, and blow-by increases.
The oil may get a tad cooler so viscosity and friction increases.
Darn, doesn't the connecting rod get cooler(and shorter) too...
You also have more weight so there decrease in the power to weight ratio.
Since there is more load on the tires an increase in rolling resistance...
You'd best intercool only wreckers and winch trucks. Power may be so low you'll need to tow/winch yourself home...
