M54 parking brake issues.
BillIdaho
Caldwell, Idaho
I recently lost my parking brake. I got underneath and discovered the inner brake lining is gone and the outer brake lining is loose on the rivets. Real loose. Luckily the drum is fine.
I went to the local Meineke muffle/brake place and tossed it up on their counter. I asked if they (or anyone else) re-lined brakes. They said no one that they knew of actually re-lines the brake shoes anymore. They advised it's a replace type of thing, rather than a re-line.
Is there a civilian replacement lining that I can buy, or something close enough that I could trim the outer dimensions and re-drill the rivet holes?
Please, some one tell me there is a cheaper way out that involves me replacing the linings myself. Re-riveting can't be that hard, I have done it on my Harley several times. I understand the parking brake is to only hold the truck stopped, NOT to be used to stop it.
And, before anyone goes off on me...I do not use it for stopping the rig.
Thanks .
zebedee
conceptualizer at large
662
Central NY
Not sure if Bill is still around... but go find the antique tractor boys. Brakes can still be relined, jusy got to find the right contact. I have an old Garwood winch and was pointed in that direction by a local Antique John Deere restorer. No idea now where that was though - 'twas a while ago, sorry.
NDT
5,859
Camp Wood/LC, TX
Send your core to heitmancompany.com, they are in Houston, relines on anything is what they do. Or buy new parts from Memphis Equipment.
