Special T
- 21
- 18
- Wetside/ WA
So i have a couple of questions that i have not found the answers to even with an advanced search.
Can a M54A2C run 1600R20 singled out? If you can flip the Hubs to run them super single what is the distance from the bolt face to the frame or anything else that can rub? A guy I know with this rig in AK that Runs on beaches is trying to get as much flotation as possible. I was thinking singled 1600R20 with low air pressure, OR trying to run 395' Dually on the rear bogey. Since its a beach runner width isnt an issue just tire/wheel clearance. Some some bridge truck wheels are available as well as some other offset wheels that may pair up Depending upon the clearances,
If your running super singles right now what is the tire size, kind of combat rim and how much space between the tire and frame or other potential rub areas?
Thanks for the help
Thanks for the help
