M62A2, what engine?
madsam
M
I was wondering what engine the M62A2 has? I thought it was a multy fuel turbo, but was not sure.
madsam
M
Does it have a turbo?
Moving over 30klbs with a multy seems slow.
I know moving it with a 250 is slow.. so how slow are these?
BKubu
1,237
Gaithersburg, MD
A multifuel wrecker has no power if it has an overdrive transmission. The only way to go IMHO is with the direct drive tranny. Your top road speed will only be 46 mph or so, but at least you'll be able to shift into 5th gear!
BKubu
1,237
Gaithersburg, MD
Yes, the multifuel 5 ton motor is turbo. Most, if not all, are whistlers. As a matter of fact, I don't think I've ever seen/heard a 5 ton multifuel that was not a whistler.
ken
27
Houston Texas
If the LDS ended up with a "C" turbo that would seriously bring it's power output down. It should have the wastegated turbo on it. Witch will wistle just as well. But move alot more air.
jatonka
111
Ephratah, New York
M62A2
I don't think there is an M62A2. There are M62s that have been converted to Multifuel engines, but they are still M62s. The Multifuel engine is a LDS 465-1A, in a 5 ton. They dont whistle much at all. They do produce some horsepower. Some. I have several 5 ton Multifuels and they dont sound like an M35A2 with a LDT 465 1C whistler turbo at all. JT
BKubu
1,237
Gaithersburg, MD
RE: M62A2
JATONKA: I had an M543A2 that whistled pretty well. I don't want to say that it whistled like a deuce with a C motor, but it definitely whistled more than a deuce with a D motor.
By the way, above I said the motor was an LDS4651C, I meant to say "1A" as JATONKA has correctly pointed out.
joeM62
Cedartown/GA.
well there is a M62A2 Jatonka because there are 3 verison of the M62 gasser, M62A1 mack,M62A2 multifuel and there are manuals on it don't know if the multifuel had a turbo or not you'll see more gasser and multifuel than the mack thou, these 3 where in the testing phase to figure out which motor would be best to the M62, not to sound like a jackass since i had old yella, I found more info on these trucks.
