M656/XM757 8x8 solutions
cranetruck
94
Meadows of Dan, Virginia
This series of trucks was designed to mil-spec from scratch and many little things show a better way to do it, as well as big things too.
Here are some images of typical mil-spec solutions.
No.2Diesel
11
Huntington, NY
Question about floatation abilities...
I understand that the cab is watertight using low psi air in the door weatherstripping. Would the front end actually float? Also, was the cargo version's cargo bed designed to be watertight and act as floatation? Would the cargo version completely float?
I like the oversized towing/lifting shackles. It eliminates a seperate part further reducing weight. Every little weight savings adds up.
cranetruck
94
The cargo version was designed to swim, generally without any preps. The cargo bed sides are all sealed with low pressure air. The cab is completely water proof with feed-through connectors and pressure sealed doors. Foam filled floatation chambers in the front help make up for the weight of the winch. Two bilge pumps are standard on the cargo version.
The engine is designed operate under water without preps, compressor air intake from engine ait filter canister, crankcase vent with valve for pressurization. Separate fan belt to allow for slippage under water without sacrifice of generator power. Dual output generator to support bilge pump operation while swimming. It goes on and on and on.
Aluminum in every possible application to save weight. The oil filter bracket on the engine is made of aluminum, the torque rods are aluminum, the cab, the cargo bed and parts of the brake drums.
Downside is that the scrappers love them.
The 8x8 weighs about 3,000 lb less than the equivalent all steel 5-ton trucks. More horse power for a better power to weight ratio.
Excellent offroad abilities, can't wait to try it out.
No.2Diesel
11
Huntington, NY
A 45K rear winch and a nice Mil LowBoy would be icing on the cake, though not original. Is the Pershing missile trailer a specific design? Or was it modified from an existing tank hauling trailer etc? How do the Soviet's counterparts compare to the 656/757?
