m715 carb
ktm25089
Greece
Hello from Greece
We have here a M715 and we need a good carb to run the engine.I cant find a good carb and i want to ask if i can fit something else except the standard military?Some holley maybe?
Thank you very much
George
NDT
6,476
Camp Wood/LC, TX
The standard military is a Holley, that carb was used on lots of other things in the 1960's and is not a bad unit. Kits are available and cores as well.
Welcome to the site. You guys in Greece have all the nice US surplus . . .
ktm25089
Greece
You guys in Greece have all the nice US surplus . . . :-D:-D:-D
And we are trying to collect them for the years that come to have spares.!!!
Can i ask what type of HOLLEY carb this engine have?And can i fit a kit that is designed for civil carb use??
Thank you
George
Kwai
Houston, TX
Holley 1920. Memphis Equipment has the rebuild kits.
Be sure to set the float level as per the instructions. It makes a big difference.
A bad coil is the most common reason the 230 ohc doesn't run. Also, you might find you need to rebuild the fuel pump.
ktm25089
Greece
Can anyone please tell me what is the correct fuel pump pressure?To see if i need to rebuild the pump?
George
