m813 Tachometer drive gear
seano11
106
Edmonton Canada
And yes I read the tm's put the pics there are very unclear. I was wondering if someone could take a picture of how there tach cable connects to the injection pump for someone reason I keep breaking tachs and cummins is saying that I need some sort of adapter for the top of the tach drive? any help would be great AND once again I did read the tm's and can't find a good clear picture
seano11
106
Edmonton Canada
Ok so if you get A total rebuild on your pump then you will need to go into a tach shop and ask to have a new tach cable built with the standard cummins key the one that is stock on the truck is normally used for gmc injection pumps and allison transmissions
markmontana
Mesquite, NV/Layton, UT
Earlier in this post there is the image of the tach cable connection. I have a truck with the cable directly connected. Of course the cable does not engage. So no tach. Cable spins freely.
Looking at other 5 tons there is a piece between the pump and the cable. See picture- it's the yellow piece. also has a couple wires. My truck has the connector that these white wires should connect to, just dangling.
What is this yellow adapter called? I need one! BTW- my M923 runs like a champ! Just want a tach.
Swamp Donkey
The Engineer
126
Gray, GA
Tachometer drive adapter: NSN 6680-01-319-2354 P/N 12258931-3
Tip driver: NSN 5340-01-290-1738 P/N 12301264
I don't know if the M809 series had the adapter or tip driver since I don't have one. The M939s with the NHC250 have both. I'll take a guess and say that whether the adapter is used or not, the tip driver is still required. I'll know for sure when I have time to do away with my adapter in a couple of weeks.
Mack90
66
Georgia
Did yall find a solution to this? My cable is threaded straight to the pump. The drive turns, but my tachometer cable is not spinning with it.
