M816 Cummins egine mods needed
Shoprat 19th Engr
prince george , va
You can use 12volt stuff ,But you have to run a single #0 wire from the battery (the one hooked to the ground ) to a new termial strip with a 60 amp fuse at the battery then run all your 12 volt stuff off the strip and fuse as you would normally . You can get at just about any speed shop
