M816 gun ring?? ?
insanejecke
Sumter/SC
OK as seen in the pic below did the m816 have a gun ring made just for them or is it how it was installed? I search and came up with nothing on the m816 gun ring? And what is the price range if its is a only 816 ring?:?:
And what are throes brackets on top of the marker lights are they factory or add on's and what is it? and if someone has a few laying around message me ill buy them and same go's for the small become light bracket.:p
gunboy1656
24
Beaver Falls, PA
The M66 could be mounted on the truck just not done very often. Gun ring average about 2500 as of late.
And above the marker lights are called lollipop lights.
insanejecke
Sumter/SC
So the M66 will work just like that? and I wish I and the money lol and there lollipop lights ok so are they just markers or more beacon's? And is that there real name or just what everyone calls them I ask is because I never seen them before and its all stuff im learning.
5,161
Yup, use a M66 ring and a standard set of legs. Also use the cab reinforcement plate. $2500-3500 is the typical price for a gun ring.
insanejecke
Sumter/SC
Thanks I was asking because I never seen a m816 with a gun ring other than that one and I did not know if it was special or something. Thanks guys and yes if I can get the funds I will be putting a gun ring on mine just because lol
zebedee
conceptualizer at large
894
Central NY
... but did you notice the "air raid" siren (?) behind the air cleaner on the drivers side? Where was the pic taken? The indicator lamp on the Jeep also begs the question of authenticity as a whole. Were the 816 mods done as per military or later to satisfy a desired look.... ... .. .
zebedee
894
Central NY
Couldnt delete the duplicate.. so I'll add.
If using standard gun ring supports, you'll probably have to rearrange/make alternative supports for rotating beacon UNLESS its a real early one - note the grille and used the red flasher next to the left turn lamp instead of rotating beacon(s).
22
Hobart, WA
That "816" has some interesting features as it's using the M543 grille rather than the rounded 816 grille; but it definitely has the 816 fender braces and a cummins in it - I think I have only seen a handful of wreckers with gun rings in pictures ranging from WWII to present day - not very common at all - but the ring was definitely fitted to them by the service (not quite as bad as when you see ambulances with gun mounts :p )
I am putting a M66 ring on my M543a2 and converting the spring seat on the passenger side to a bench seat so you can use the gunners platform...
Matt
