Cycletek
- 4
- 18
- Panguitch, Utah
I will, it may be a bit pricey.method to increase the mid rpm torque slightly to aid in up hill performance. do u mine sharing after u finish it?
The OP will still be stuck at 50 to 55 mph if he is lucky,, though I guess he could quad tubo the 8v92Here's another option: http://www.steelsoldiers.com/showthread.php?89363-M984E1-HEMTT-Wrecker
SAME reason u need more money. BECAUSE I WANT IT i don't plan on lifting anything to be honest or pulling or drag racing. ALL i want is more power why cant i get someone to answer my question? what the problem here??? Do you guys just want to piss me off? few of you have answer some of my question and i thank you for that the rest idk what yall problem is but yall need to lose it. If you cant answer the question all i ask is you not to try and hijack my thread and that what you people are doing can you please stop it?What do you need more power for ?, a deadmaned m816 CAN break the rear 3/4" cable at idle, a m816 CAN break the front winch and/or cable at idle, a m816 WILL lift anything with the crane at idle (better control at about 1000 rpm), so again, WHY DO YOU NEED MORE POWER ?
