M817 Turn Signal issue
USMC4302
So. MD
Searched, found no similar issues discussed: Right rear turn signal doesn't indicate/flash. All other lights function properly (right front turn indicator, both brake lights, marker lights, head lights, black out lights, etc, etc). Bulb checked good. Checked grounds and connections at rear. Checked canon plug at the turn indicator switch on the column (disconnected it, checked for loose things, reconnected it, jiggled it ...).
What should I check next, or does anyone already know the answer? Could someone direct me to the right place in the right TM to find the pin diagram/schematic for the canon plug at the T/I switch if that's the answer.
Thanks in advance.
NDT
6,346
Camp Wood/LC, TX
Defective turn indicator switch is almost always the cause of this type of problem when bulbs and grounds are good.
Swamp Donkey
The Engineer
119
Gray, GA
NDT is correct. There are several contacts in the switch. I'd disassemble it and clean the contacts. I had the same issue on a older style switch and it was dry, hardened grease causing the problem.
