m818 brake issues
emr
25
landing , new jersey
I dont have my 813 anymore so I have a 5 ton air pack new for sale 175 if interested, and a set of wheel seals too, inner and outers, good luck :)
1,188
If you read carefully, he has not removed the drum yet!
dezert ratt
14
menifee, ca
Im guessing its all the components going into failure. Sticking wheel cylinder, and malfunctioning adjusters. Possibly from being too tight, and overheating everything. Ill know more when i have the right tools to get the hub apart. The brakes dragging has caused the tire to start wearing funny (cupping). I will post pics when i tear it down.
dezert ratt
14
menifee, ca
Ive got my eye on a complete 5 ton front axle. It would be nice to pick it up for spare parts if I can get the cash together. My spindle nut sockets will be in tomoro. Just need the weather to.clear up. I cant wait!
m816
Chatham, NJ
If you have worn out brakes on one axel, It is time to pull off all the wheels and pack all the berings and replace the seals and really check all the brake shoes and don't forget to inspect all the lines and especially the flex hoses for dry rot. I haven't had a five ton yet that didn't need a complete brake job. They seem to have been run harder, longer than the deuces. All the work is definitely worth it
dezert ratt
14
menifee, ca
If a truck gets scrapped im not one to go buy new parts when there are perfectly good ones layin around. There are some exceptions with consumable parts. In my case, I needed the backing plate and adjustment hardware (not a consumable like linings, and wheel seals). And if any fellow so cal guys need front 5 ton axle parts, just let me know. I know some of this stuff is harder to find in the wild west out here. Gotta stock up when the oppurtunity presents itself.
dezert ratt
14
menifee, ca
Ive been so busy with work, that i havent had any time to wrench on the truck. Heres a pic of the start of my (soldier B) a helpful tool for removing the hubs on the truck without damage to the seals and snouts. I sacrificed a perfectly good spare 5 ton rim. I will be making a adapter to bolt the cut up wheel center to my transmission jack. Hopefully it will work how i plan :confused:
