M818 Rebuild w/ Deuce Bed
Lonnie
20
Pittsburgh, PA
I have been reading up on here for about a year since I bought my M818 last year.
It is in pretty good shape, plus it already had 16.00's & a bunch of spare parts (including turbo & manifold).
After some pressure washing & cleaning....
Lonnie
20
Pittsburgh, PA
I started on the bed last December....
Wasn't sure how my progress would be, so I didn't start the thread last year & keep everyone hanging.
This is how I spent a week between Christmas & New Years.
After Sandblasting
After Epoxy Primer...
After extensive hammering & smoothing....
And finally with some paint...
Lonnie
20
Pittsburgh, PA
Yes it took way more time than I expected.
Bed lined the inside as well just to keep it in good condition.
Just my luck that 1 bed liner kit wasn't enough... at least I have enough to do the cab floor now.
Lonnie
20
Pittsburgh, PA
I started gathering parts up with the intention of hitting it hard this past spring.
Found a set of new HEMTT rims locally & picked up a set of new bead locks from a vendor here.
Bought a new Camo soft top & got a very nice cargo cover from a member here.
I found a new set of roof bows & corners to complete my parts list.
At this point I had most of what I needed, just had to find the time to start working on it.
Lonnie
20
Pittsburgh, PA
Started removing the 5th wheel. It appeared to be unused.
I bet it weighs 500lb.
The front rack was also removed.
Another heavy part.
Finally I'm down to the frame.
The next step is to start pulling the wheels & drums to check brakes & replace seals etc.
Lonnie
20
Pittsburgh, PA
Pulled the tires, wheels & brakes to check everything out.
Started cleaning/pressure washing the frame in preparation for paint.
Frame is primed.
& finally in paint
Next will be the brake rebuild..
Lonnie
20
Pittsburgh, PA
Here are some pictures of the brakes, bearings etc.
Had 2 bearing seals leaking & 1 wheel cylinder was wet.
All bearings checked out good. Repacked bearings & put in all new seals.
Wheel cylinders were nice, so I put in new cups & put it back together.
Also replaced all brake hoses.
Lonnie
20
Pittsburgh, PA
Time for some body pictures.
Had the help of my friend to get the bed on.
A couple machines made it easy.
Here is it installed.
It's definitely tall...
