citizensoldier
- 16
- 38
- Northern Michigan. Smelt City
My M818 will not go into or has no Low range. At first I thought maybe the linkage was out of wack but I unhooked the linkage and used a big pry bar on the shaft. It is out as far as it will go. When I put it in gear it will not move and feels like it wants to grab but will not engage. I see some type of access hole on the side where the High/Low shaft enters the case. I have many manuals but nothing shows a blow up of how that shaft works or what is in that section. I am just wondering if its something simple like maybe a keyway is sheared or broken shaft? Or is my T case toast and time to swap it out. Ughh.. 800lbs of fun in the shop..Is that adjustable some how inside the case?
