bassetdeuce
- 6
- 0
- Orange City, FL
I couldnt find a TM for the 5 ton transmission, 6353 spicer? I need to replace a leaky rear seal so could someone tell me if Im on the right track?
1. Remove the short drive shaft that goes from the transmission to the transfer by removing flange bolts on both ends.
2. Take cotter pin and nut off the output shaft.
2. Remove companion flange off of the transmission with a gear puller.
3. Remove the the bolts holding the bearing cap and remove bearing cap and gasket.
4. Tap out the old seal from the bearing cap.
5. Tap in new seal.
6. Reassemble with a new bearing cap gasket.
Is this correct or am I missing something?
5. Tap in new seal.
