M880 lift
dodjh
14
Central, MS.
Hi All, a week or so ago I put some run flat 36 X 12:50 X 16.5 Hummer tires on my stock '76' M 880. I also put 2"
spacers on all four axle lug nuts.
My rear tires don't rub but my front do...need more clearance. Would an additional spring on the front pick the body up
enough to prevent rubbing? I've had springs re-arched before and wasn't pleased with the result.
lostintexas
Houston, TX
What are you doing when you rub? If you are getting any rub on the street you need at least 4" of lift if you are doing anything serious offroad. If you are staying on the street with occasional rub at full lock then 1" would probably do it with 2" being safe.
dodjh
14
Central, MS.
Would I need to do the 2" on the rear also.
What type of 2" lift would you do, blocks, body lift rubbers or extra springs?
dodjh
14
Central, MS.
The rub is happening when I turn the front tires. I notice yesterday there are vertical cuts in the fronts. There isn't a lot of clearance when they touch the fenders while turning.
lostintexas
Houston, TX
Yeah, add-a-leafs will stop the rub when turning. If you are taking it offroad and flexing the truck you need list all around. Does the nose of you truck sag in the front? While I'm not a fan of body lifts that would be an inexpensive option too.
dodjh
14
Central, MS.
My front leafs are 3 in total. How do you add a leaf to that and what position on the springs would it be placed? The longest is 4'.
Are you suggesting using body lift rubbers instead of leafs to lift it up from rubbing?
The rubbing is occurring mostly on driver front tire.
It does seem the nose is sagging in the front.
dodjh
14
Central, MS.
I looked at a set of leaf springs not mounted on a truck. They look fairly flat...maybe 1 - 2" of rise from middle to each end. Is that about what you would expect
or should there be more? These haven't been used much...the sticker is still on them.
WVCB
Durbin WV
Not spring related, but some of the front end sag on my W-200 was caused by the two rubber body mounts at the front rotting out. They were completely gone; front clip sitting right on the frame. I replaced all the body mount bushings with polyurethane. Noticeable difference.
dodjh
14
Central, MS.
I will have to check mine...probably the same condition as yours were. I have added a leaf spring in the mean time but may get some more lift from the body mounts.
dodjh
14
Central, MS.
On the front spring plate, there is a nut inboard but can't drive it through. Does it have a spring clip that has to be removed first?
The nut is off but not having much success on removing the bolt from the plate.
dodjh
14
Central, MS.
How many springs would ya use to keep the front up? Needing 2" for the run flats, I have a bumper that weighs 350 to 400 pounds. Drill pipe, 2"
Bob H
155
Not sure what you're askin', the plate should lift off the studs once the nuts are removed.
1st pic my plow truck - M884 with add a leaf
2nd pic an M880 series springs
dodjh
14
Central, MS.
I'm not sure either....I need a spring lift to have c;clearance for a 12"50:16 X 12:50 X 16:5. I took a leaf from a set up from another 16.5
What do I do to gain the clearance from stock>?.
Bob H
155
the add a leaf spring is about just as long as the main leaf. it is also arched, if you simply added a leaf of the same length as one of the shorter ones you would only gain the thickness of that leaf, basically just a spacer.
refer to picture #1 above, before that "add a leaf" the rubber stopper was almost touching the spring, so I gained nearly two inches
