M880 My pile of bolts.
1977 Dodge Power Wagon M882
3/4 open diff
318 2bbl
727 3 spd
np203
It's the 3 color camo, with some rustoleum sprayed over for now. Thinking of going desert 4 color, or an easier over all OLVE DRAB. Input appreciated
I haven't really had the money to do much to the truck yet.
So far
4 new batteries Rolling Eyes
New Alternator and belts
New brake booster/master cylinder
Distributer, rotor and cap
plugs and wires
Power Steering pump
RADIATOR
31" BFG Trac Edge Tires
New gauges so I can see my oil pressure
F.O.R. Bedliner Laughing
Black tuff lined the interior
Broke a taillight
Rebuilt the Carb
Changed all the fluids (ALL)
Greased it like a monkey
It's still got issues I'm working on, mainly the carb. I brokeded it on accident. Hell the speedometer started working again after I dropped off a 4 ft. cliff. Laughing
Next plans in order
SINGLE DEUCE STACK IN THE BED
NEW GAUGES/DASH
NEW INTAKE AND CARB
IGNITION/COIL
SNORKEL
After all the minor stuff is taken care of, It'll get 8" leafs 2" body lift and some 39.5 boggers and 38x18-20 tractors
Need to put new outers on the front so I can install a locker, also plan on an np203-200 doubler, 440 big block with 2 4's.
This will all come with time..........and money.........$$$
Alredneck
Banned
1,494
15
TN
Lots of potential, heck worse case if it doesnt work out you can take it out in the woods and burn it to the ground, the sad thing is it would probably limp home behind yea like a broke down dog but hey its a dodge. Good luck in your work ahead of ya!
AJMBLAZER
Paducah, KY
Going to need deeper gears and larger axles if you want to play hard with those 38's. A locker in the rear would be good too.
My kind of truck though. Trucks shouldn't be pretty...well, 4x4 ones at least.
