citizensoldier
- 16
- 38
- Northern Michigan. Smelt City
Ok, the shop truck topper is probably coming off the M887 and she will be getting a Warn winch bumper with shackles for tow baring and Western plow set up for this winter. I would like to put a stake truck type dump on the back. I see the T case has a PTO access. What PTO works on this Tcase? Or should I go with some other type of propulsion for the dump?
I am also considering a Detroit Locker for the rear axle.. Any pro's or cons to doing this? Other lockers work better?
And Bob H if your reading this.. Did you have to lift that M880 for those HUMMV tires to fit? Or just cut the front fender a little?
Thanks in advance to all that might help..
