M880 Troop Seats
Bob H
161
Huron National Forest, Michigan USA
Yes those would be the M880 series seats, they are interchangeable with the CUCV's, although the CUCV's got aluminum slats instead of the wood. (if not when 1st produced, then somewhere down the line.)
McGuyver
Utah
Are you sure they're interchangeable with the CUCV? I know the M880 troop seats have one leg that is shorter to accomodate the gas filler neck hump, and I'd be surprised if they were located in the same place and same dimensions as on the M880.
Bob H
161
Re: RE: M880 Troop Seats
Good observation!
I have seen several CUCV's with the M880 sets at Camp Grayling, the shorter leg still contacts the floor and supports weight, but is not correct.
While I haven't seen the CUCV set on a M880, this is nothing a sawzall wouldn't take care of :shock:
Boatcarpenter
Marlborough, NH
RE: Re: RE: M880 Troop Seats
I looked at the ones pictured today and they appear to have three shorter legs which I assume are for around the wheel well intruding into the bed.
