M915A1 Detroit Lockers?
Autocar
15
California
I was looking at the door panel tags on my 1984 M915A1 and found two warning tags about use of Detroit Lockers. Does this mean that my truck has lockers in it? If so, was this standard or did I just get lucky?
Autocar
15
California
I pulled up the manual and it doesn't say anything about lockers, but when you pull up the parts breakdown, it shows a "no-spin" differential that looks like a locker. I guess this means that all M915A1s had lockers in both axles.
Monkeyboyarmy
192
Kingsville,Oh.
They are supposed to have a locker in the forward rear. The 916's-920's had lockers in both axles. NDT...you could hve a broken axle shaft in the forward rear.
NDT
5,919
Camp Wood/LC, TX
Both rear axles will spin one side (on grass). I can't get mine to do any smoky burnouts on pavement. It's all go when 400 horses gets unleashed.
pctrans
19
Bradenton, FL
I think you have a defective truck. You need to take those axles out imediately and I will replace them with the correct ones. :jumpin:
Floridianson
2,439
Interlachen Fl.
Jack up rear spin tires. Same direction lockers different direction open diff. Find mud on a slant hill lockers both will spin open diff the upper side kick out down hill side will do nothing. Your stuck.
Castle Bravo
Hundredaire Socialite
221
Arizona
I'm not sure if this is the same picture you're trying to show or not, but this says that the M915 has 1 locker and that the others 916-920 have 2 lockers.
I have yet to determine what my M916 has yet.
