M915A1 Dump transformation
panzerwillie
329
miami florida
Ok Boys & a Girls work on it today for few hours put the Disc with new sesls torque to factory specs it has cone spacer between the bearings wich makes it easier , have not put calipers and brackets yet but will follow soon just wanted to see it with the 425/65/22.5 this axle is about 3 inch wide hub face to hub face but looks good at the end i made run 385/65/22.5
panzerwillie
329
miami florida
Well work on it for a few hours . Started with the replacements of rear hubs to hub sentric ,had to make a quick tool because at least one of the two on driver side was stuck like CHUCK next week will tackle the other side..
US6x4
2,532
Wenatchee, WA
There's a little drop down menu in the bottom-left of your post that will expose an "edit" option that allows you to correct the original post (see below)
