- 648
- 519
- 93
- Reydon, OK
I had an inside oil seal leaking on right rear. Pulled it apart and inside seal had been damaged when military rebuilt. Axle flange had rtv sealant only. No gasket or seals. Parts manual shows outer oil seals just under axle flange. They consist of 2 paper gaskets and an 8 hole metal oil seal that sandwich together when axle is installed. What is the purpose of this type seal?
