M916 conversion to 2500 Gallon Tanker/Pumper for a volunteer fire department
Chief478
Georgia
My small rural Georgia VFD just got a M16 (1993 yr) to convert to a tanker/pumper. We don't need the PTO, because the Pump is driven by a separate small diesel engine . We are removing the 5th wheel and winch components. So, I was thinking of just capping off all the lines at the PTO pump. Any thoughts on the winch removal?
Also, the truck hasn't been ran in about 5 years. We're changing all the fluids and flushing the fuel system, before trying to start it. Any thoughts on initial start up after its been setting that long?
Thanks, Butch
19,461
Thanks, Butch
I am guessing that you need that extra two feet of space for the new tank? Where the winch is now... And you don't have a possible need to pull something with a winch?
One thing you need to consider is that "capping off the winch hydraulics" could stop the motor dead. Especially if somebody engages the winch PTO and it "dead heads" . With the pump blocked off, you won't get it to crank again until that pressure is relieved. A better idea if you really don't want to remove everything would be to loop the hoses "in to out". The pump and pto won't last long running in that configuration either... And the pump will be screaming
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Thanks, Butch
Takes 20mins to pull the winch off.
You will need a 3/4" socket and wrench for the pto pump. Remove the pump at the PTO and leave the pto on the truck.
The hydraulic system generally doesn't have a drain on them so pull it as a complete unit with the pump still hooked to the lines
GopherHill
1,236
Thomaston, TX
You might want to rethink winch removal. You will eventually stick the tanker and it will be really hard to extract. Been there, didn't get a tee shirt. I've been a VFD member for 30 plus years.
simp5782
9,329
Mason, TN
How are you going to use the winch if it's in front of the tank?
It's better to use them to pull a 5000 gallon tanker
Chief478
Georgia
Thanks for the info. This is a new project for us.
Chief478
Georgia
Thanks for the info, I'll check out the You tube.
