M916 Engine Oil and Filters
st8drumz
Romeo, Mi
Ok need clarification/updated info. 1980 M916 - Lube order says (best I can tell) straight 30 weight oil. Is that STILL good info or is there something better for the Cummins NTC 400?
NDT
7,107
Camp Wood/LC, TX
That’s a good question. Since oil changes on these is like a $300 deal, I tend to stretch the intervals since the oil always looks amber on my lightly used 400’s. If you operate in dusty environments, keep with the lube order.
Hammer
398
Winlock, WA
Well, I highly doubt most people put enough mileage on them to go by mileage (obvious exceptions like Simp, etc.)
So a TIME based interval is usually a better option to use.
You will most likely not run the engine enough to get enough soot, crud, etc. into the oil. So think about the acidic break down of fuel, soot, etc. that makes it into the oil.
I would say, depending on a few things, yearly, or some longer interval based on every 1,2,3,4 years, based on a somewhat regular interval.
If you have an accurate hour meter, this is another method to use.
And for the pretty low cost, getting an oil sample done every once in a while, should tell you whether you need to be changing the oil more or less often.
Btw, if you start your engine to 'just let it warm up', all the time, you are going to want to change the oil more often then just letting it sit without starting it.
Personally, on the big stuff, I like to change the oils every year or two. Unless I am working them.
