- 1,230
- 466
- 83
- Guymon, OK
![IMG_2596[1].jpg IMG_2596[1].jpg](https://www.steelsoldiers.com/data/attachments/504/504407-9a28007314135f22da0b4ef9b2656a03.jpg)
So we went on another run earlier this week, only for a refill and just rough math in my head AMi gets about 4mpg at 55-58 mph. Also 55 is a bit slow going to a fire. She has no problems tanker yanking full to the top of water, so another .81 od behind an aux should get the top speed at 2100rpm to 69mph with no HP issues. Hopefully lowering the RPM will help with the MPG as well. I know it takes along time to pay for parts on MPG alone, so the mpg would only be icing on the cake.
Doing some research, I have found an aux transmission to throw behind the transfer. Spicer 1750, looks to be large enough to contain the torque
I know that I loose my front axle running in OD, but I can set it up so that the air operated part wont work unless the aux tranny is in direct.
Has someone done this before?
What other negatives am I not seeing.
Any suggestions, comments, complaints? I have read alot of threads on the duece's with the little brownie, but never saw one that someone actually did.
