- 2,868
- 27
- 38
- Delta, PA.
I just bought a m916a1 today.Dam what a sweet and powerful truck.Are these trucks all 24 volt or is just the starter and charging system 24 volt.I want to run some 12 volt accessories.
The big Allison's behave the best when you bring the RPM's up to about 200 below governed and just hold it there.With a tag-a-long you might not notice it is there! Been pulling a M172A1 and have learned a little about this model Allison-it appears to be set up to work with full throttle up to your target speed (when loaded). Smoothest shifts work out this way- not with the throttle feathering you might find yourself doing on lighter models.
The unloaded ride is so good that I took it bob-tailed a couple of times.
