M917 died suddenly.
Abrant23
186
Charleston, SC
So, today I was driving down the road in front of the property and my 917 died. It just immediately stopped running like it ran out of fuel. (I checked, there's half tank)
So, browsing and searching the forums has led me to believe that it could be a fuel solenoid. Apparently there is a screw to override this? Anyone have pictures or suggestions on what exactly I should be looking for?
Lastly, is there another problem I should be considering?
Any help would be greatly appreciated
-Alvin
jcappeljr
27
Delta, PA.
Its a thumb screw on of the injector pump.Right were the electric fuel shut off selinoid is.Screw it in.
Abrant23
186
Charleston, SC
Do I have to unscrew it when I shut the truck down? I assume this is just a temporary fix till I replace the solenoid?
Bigjohn066
Lawrenceville, GA
On Friday my M934 did the same thing. I ended up putting pressure in the tank to pressurize the fuel system. There was a hole in my fuel filter. Showed up right away.
Abrant23
186
Charleston, SC
I had to hook a cable to it and pull it onto the property with the tractor. We don't have cell service out there so I didn't find out about the solenoid till this evening. Hopefully she'll crank in the morning!
