- 7,406
- 2,498
- 113
- Interlachen Fl.
ok, thanks, it looks like the drivelines were in place when it was rebuilt in 2005 seeing as it got a fresh coat of carc then and none is chipped off the bolt heads. Now what is a drop box pump?
Seems like some like to call them drop boxs most say transfer case.
There is two places I check the fluid. main box and front output. You will see the two fill plugs. Big and small pass. side.
You probely been reading threads but on gear slection the engine must start increasing and truck picking up speed in 3 seconds. It hard on clutches to stay at or around 750 to 1100 rpm for long. That is when ingagement is happening.
Need anything call James 352-262-0398
