M920 Transmission Swap
19,087
Has anyone ever swapped a 13 or 18 speed in place of the 7155 Cat in an M920? Is there enough room without relocating the transfer case?
Check in with @simp5782
Cab needs to be higher, transfer case needs to move back, jackshaft needs to be modified. It isn't an easy thing to do.
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
A 13 fits without moving it. With a .73 ratio unit you gain 5mph or so in speed.
Use a hydraulic clutch from a freightliner cascadia and the wabco air assist hydraulic slave. This setup requires a specific clutch for hydraulic. This is the easiest pedal install over manual linkage
The PTO swaps over directly as well from the CAT
I went with an RTOO14613
