TheUziButton
- 0
- 1
- Dayton, Oh
Maybe it is because of your avatar.Just take it off and put new gaskets in. Or go to a truck stop and buy a new one.Welcome to the site, I'll be in Dayton tomorrow. Ohio has quite the growing number of members.
Last time I checked Michigan was close to Ohio-- Idk-- just saying.Maybe it is because of your avatar.
Does the on/off valve need to be removed from the gladhand, and then disassembled to access the o-ring on the stem or can I take the stem out without having to remove it. I took the handle off the on/off valve to access the stem but I cannot figure out how to remove it from the valve body.Take it apart and replace the o ring on the stem. Easy fix.
It has to come off. Separate the valve, ( it's screwed together ) push out the ball, ( it is slotted on the top where the stem is ) then push the stem down and thru the valve body to replace the o ring.Does the on/off valve need to be removed from the gladhand, and then disassembled to access the o-ring on the stem or can I take the stem out without having to remove it. I took the handle off the on/off valve to access the stem but I cannot figure out how to remove it from the valve body.
Thank you! I will give it a try this weekend!It has to come off. Separate the valve, ( it's screwed together ) push out the ball, ( it is slotted on the top where the stem is ) then push the stem down and thru the valve body to replace the o ring.
