M923 air conditioning a/c install project
Buffalobwana
179
Frisco Texas
It is called determination, and I applaud him for it. And I applaud the guy who filmed it. One of the funnier things I have seen on FB lately.
Buffalobwana
179
Frisco Texas
What kit? The complete AC system? $1200 or so
the Alternator/compressor mount kit? I forget, but I'm sure he will chime in soon and tell you.
If you are wanting to do an AC on your 939A2, Clint and I have a package special for his bracket and one of my NOS 40,000 BTU compressor for $320 ($140:bracket / $180:compressor) total for both, shipped CONUS only. Will ship Alaska HI for a bit more of course.
74M35A2
342
Livonia, MI
Photo of said compressor with 8 rib clutch pulley installed. You can typically use the 10 rib pulley the compressor comes with. This is not the adaptive bracket pictured, which is why I had to swap to an 8 rib pulley.
Buffalobwana
179
Frisco Texas
Here is the compressor I am going to use on the tan truck. It's a 40,000btu MRAP compressor. You can use the 10 rib installed clutch/pulley on an 8 rib belt, if you use 74M35A2's special bracket (not the usual A2 bracket), it will save some $ (check classified section or PM me)
I'll be using all the same parts i used on this camo truck; H1 kit with evaporator, condensor, wiring harness, dryer etc. Only, this time, I bought all the parts separate instead of in a kit.
if you need a H1 pulley, I know I saw one in the garage yesterday. Just need to locate it ...
Buffalobwana
179
Frisco Texas
Restomod Air
A/C Kit for M998 HUMVEE – HMMWV
Coppell/Texas
Humvee Air’s HMMWV Climate Control system is like nothing else on the market. Computer aided design and flexible duct hoses allows for the best performance offered by anyone. Made from STEEL not preformed plastic this is the most durable system available guaranteed! This system is complete and contains what you’ll need to get modern day, high performance A/C, heat and dehumidified defrost into your HMMVW.
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
The only time a hmmwv air conditioner may he releavant to a m923 is when the 5 ton parks on top of the hmmwv.
