ClintA
- 14
- 18
- Mule Creek, NM
The Ranch bought a M923 that had been sitting for who knows how long. Long story short the PT pump was gummed up (remind you of pine tar) the throttle shaft was so sticky that the spring on the throttle linkage was not strong enough to pull it back to Idle, so reaching down or pulling up with toe it would die. So taking the PT pump apart and cleaning everything the throttle shaft is free to move back and forth with no effort. Starting the truck and now she wants to run off, so I did research and tried to adjust the throttle screw and still no dice. The truck wants to idle close to 20,000 RPM's no matter what I do. I took the throttle linkage off and made it as short as I could and that lowered it down to 19,000 RPM's. What am I missing?
Thanks in advance, Clint
