M923: LOW hours but "high" miles?
MO MV man
Imperial, MO
Hello all,
I've been eyeballing numerous M923's as of late and have seen many with super low hours (say 20-50, for example) but "high" miles; 20,000-40,000, for example.
Am I to assume the engine is fresh and the hour meter was replaced when the engine was replaced?
Thanks a lot.
MWMULES
352
DESOTO, KANSAS
With surplus, never assume = (ass out of U & me)! Best way is to eyeball in person some are as you think and others may have a non operating hour meter or had it replaced without the motor being replaced. A lot of 900 series have been through partial or full rebuild and some are original.
emmado22
170
Mid Hudson Valley NY
Dont assume any hour meter or odometer is correct or original to the truck. The military does NOT treat odometers like the civilian world does. Look at the condition of the truck as a whole to see if the gauges "seem" to be correct for the amount fo wear.
MO MV man
Imperial, MO
The M923 I got shows 19637 on the odometer and 18202 on the RRAD rebuild tag.
Engine and everything surrounding it is beautiful so I'm betting it has 1435 miles as indicated.
My tach and hour meter are not functioning at this time so an accurate hour reading is unknown.
Another item on my "to do" list. :)
Scarecrow1
Florence , S.C.
I agree with all those above . there is nothing to say that even the whole instrument cluster hasn't be replaced . Many of you remember when the gauges where being stripped form the Deuce's because of the radiation levels . So you really can't count on anything but the date you bought it .......
wsucougarx
71
Washington State
With my truck, the mile meter registers 83,000 miles. However, the hour meter indicates 40 hours. Looking at the motor it has a rebuild tag of 2008 and the truck was turned in March 2011. So it appears the hour meter was replaced with the rebuilt motor?
BigWill1985
Norfolk, VA
Where are the engine rebuild tags? The motor in my M817 purrs like a kitten, and the speedo shows ~47,000 miles. I am curious as to whether or not it has been rebuilt.
~Will Courtier~
