- 4,235
- 2,938
- 113
- Fort Worth, Texas
I've got an atypical issue I've not had before and looking for input. I've got a m923 that keeps getting a small air bubble in the line near the lift pump when the truck is off. It doesn't drain down to the filter, it just forms a bubble enough to stall the engine from a start. I've swapped all the lines from tank to pump, rebuilt the hand pump, tried capping it off, pressurized the tank and fuel lines for leaks (none seen), and it still looses prime to stall out. After another quick crank (maybe 3-5 seconds) it fires up and all is good in the world. I know the air has to come from somewhere but where..? Thoughts?
