Doomsday
- 0
- 0
- Castaic, CA
So, basically out of the blue, the transmission is not shifting into any of the forward gears. Truck had been running fine last weekend, went to go to pull it out to wash it up today and no go. Weird thing is, it goes into reverse just fine but then switching to 1-5 or any other gear set, it just acts like its still in neutral. Opened up the access door from cab and it makes a buzzing noise in neutral but then goes away when putting shifter into gear. Shut engine down and tried starting it in gear and no go, so thats normal. Put back in neutral and starts like normal. Fluid level is normal, nothing leaking, nothing looks out of place that I can see, transfer case is in gear, tried shifting it out of high to low and no change.......Very confusing how it just has sat for a week then suddenly it just doesn't work. Unfortunately I am not an auto trans guy, never owned an auto trans truck in my life, always been a manual trans owner and am still new to the 5 ton world. Please help with any gremlin advice!
Thanks guys!
Thanks guys!
