M923a1 abs
238
Las cruces nm
My truck doesnt have the antilock brake system but i am thinking of getting it upgraded. There is a guy here locally that is parting out his truck hich has abs and i am thinking of taking the parts fom his truck and transfering them to mine. What parts do i need if i were to do it? Would it even be worth the trouble if i were to do it? What would a reasonable price be for the antilock brake system?
juanprado
2,866
Metairie/La (N'awlins)
It is a lot of work. Major parts are the abs ecm with the main valve, other solenoid with valve, (both at the rear axles) air dryer, 2 wheel sensors, all wiring from sensors to valves to dash light and passenger side cab diagnostic connector. There is also the plumbing air lines and I believe there are other valves (relay and ?) that also need changing.
Another member sent me the abs upgrade tm/ instruction manual. I believe I have it at home. I will let you know later. PM your email as I think it is too big to post.
Scarecrow1
Florence , S.C.
Wow that just sounds like a lot of work for just an ABS system . I'm just saying with the prices of the 5 ton's lately wouldn't it be easier to sell yours and buy one already equipped with it . I understand it being needed in snow and ice but, I really wonder about it's need in our southern most states . No offense just asking .
1,174
It's needed more in good traction conditions, to keep from sliding sideways and tipping over.
jonesal
Mission Specialist
69
Brookings, SD
If you have the MWO for ABS, it is very detailed, and I would think it very doable. It would take a couple of days to make it happen.
Al Jones
Scarecrow1
Florence , S.C.
I think that you have the Marines version of the A1, I read where it was made to fit the size of their shipping cubes .What gave it away was it had 5 dropping sides and it was also a foot longer the most . The standard length is 14 ft. So this is the one you will find a 923A1 missing panel from.... good luck
