M923A1 shifter stuck in reverse.
Hooper
Grand Rapids
Well, before I go out in the cold to repair. I thought I would see if anyone else has had this happen. I was parking my truck and when I went to shift out of reverse, the selector would not move. My hunch is that the cable release is simply not moving far enough to allow it to come out. Anyone else have a suggestion.
GHall
San Antonio/TX
Maybe grab another person to work that shifter while you're underneath the vehicle.. With the truck off, on a flat surface, the wheels chocked and the parking brake on. Maybe a little spray lube on the shift linkages. Was the truck warmed up or real cold when you noticed the problem?
Ferroequinologist
Resident railroad expert
724
Liberty Hill, SC
I would guess the cable is binding, or it could even have broken.
I agree with GHall, get someone to sit under the truck and see what's going on when the shifter is moved.
Hooper
Grand Rapids
Maybe grab another person to work that shifter while you're underneath the vehicle.. With the truck off, on a flat surface, the wheels chocked and the parking break on. Maybe a little spray lube on the shift linkages. Was the truck warmed up or real cold when you noticed the problem?
I had driven to work with it. It has always taken a small tug to get it out.
Ferroequinologist
724
Liberty Hill, SC
I've had similar cables break and then when the cable started to unraval inside the housing, it froze up.
I agree the most likely cause is a binding cable.
