M923a2 and a M105A2 trailer
Gunzy
66
Roy, Utah
No, but my M105A2 leans down in front when connected. I need to flip the lunette on it yet but it is VERY tight into the tongue.
98G
Former SSG
4,378
Yes but in will lean to the front and is really heavy. You would be better off with an M1016A1 trailer.
They make (or you can fabricate) a draw bar for them. Otherwise, no it won't hook up. Either way, the RBU won't be powered.
As Gunzy said, they're heavy...
I'm picking up a mk16 July 2nd, using an M923A2 as the prime mover. I'll post more on it when I have something relevant to say...
wreckerman893
Possum Connoisseur
15,626
2,039
If you will notice on the trucks with super singles the pintal hitch sits lower than on the ones that came stock with the 1100 tires. I think there was a modification when they rebuilt the A1's into the A2's. On the older trucks the hitch went through the rear crossmember, on the newer ones it sits below the crossmember on a heavy piece of steel attached to the crossmember.
DJones
57
New Palestine Indiana
My truck in post #13 is actually a 1984 M925, I put the super singles on it but it has the heavy piece of steel that Wreckerman speaks of.
Psycho Path
Collinsville/OK
Thanks everyone for the replies on the Oshkosh MK14 hook up to M923a2. I'll check out some of your suggestions. It would be nice to find an 18 - 21 foot flatbed that matches up to the bed of the M923a2. Thanks.
