- 6,093
- 4,499
- 113
I've got a lever for your heater switch, and a tan mudflap assembly for you... trying to think of anything else ...
Good times..Well, the story of my life with MV's lol. I was out for a drive and the turn signals quit working on me. Was out driving for abut 30 minutes and a little over half way I went to turn and the light on the turn signal switch wouldn't flash, it lit up but didn't flash. I got it to the house and checked and sure enough no turn signals. I don't get left, right, or 4 way. I guess I will take some time and start checking components and looking for loose connections.
Yeah. Lol. I had this happen to me before and the only way I was able to fix it was replace all the components. Granted it was an older truck so there wasnt a whole lot in between the components. I'm hoping this time it's just a loose connection or something. I didn't really get a chance to look at it since it was getting dark. She will just have to stay parked until I get this issue resolved.Good times..
If it turns out to be the lever assembly I've got one you can have.Yeah. Lol. I had this happen to me before and the only way I was able to fix it was replace all the components. Granted it was an older truck so there wasnt a whole lot in between the components. I'm hoping this time it's just a loose connection or something. I didn't really get a chance to look at it since it was getting dark. She will just have to stay parked until I get this issue resolved.
Figured. Make sure the connector is clean and if you have the gel, slap some in there.Well, I got the turn signal issue fixed. Turns out it was just a loose connection to the flasher relay. Tightened the connector a couple turns and everything works again.
