bjsmith
- 1
- 0
- zachary,la
You guys do really well with all of this. I like to see the batteries bolted down, etc.... As a starter and alternator guy myself, and working for said company, I beg to ask, why the obsession with adding so much battery and/or alternator capability to a vehicle where the only real load is the headlights and maybe the heater blower if on hi? Especially with an A2 8.3, that engine starts quick. I threw 2, well really all 4, of my stock batteries out the window (smittyjr355 caught them), and dropped down two 2 group 31's to gain storage room under the pass seat. Even with that, I can start the truck at 0F with no block heater and no starting fluid. If it is just a more=better thing, I get it, and do it also sometimes. Enough said. But if there is a specific reason, I'm interested in learning that too. I watched a battery explode once during cranking, and I am just scared to death of them now, and understand why they are always encased in a steel somehow. For me, less is better, down to what you need. BJS, your lower additional bracket looks great. Nice work on that. I am doing the same to add a serpentine driven A/C compressor to my 925A2 (8.3L) with a cab roof evaporator (Red Dot).
Pm meI have a spare dual volt ( 12 & 24 ) 200amp alternator for my LMTV , thinking I should sell it
Do you think I would be ok adding a 45amp load on a stock A2 truck with 2 group 31's? Or should I go for one of your upgraded alternators?You guys do really well with all of this. I like to see the batteries bolted down, etc.... As a starter and alternator guy myself, and working for said company, I beg to ask, why the obsession with adding so much battery and/or alternator capability to a vehicle where the only real load is the headlights and maybe the heater blower if on hi? Especially with an A2 8.3, that engine starts quick. I threw 2, well really all 4, of my stock batteries out the window (smittyjr355 caught them), and dropped down two 2 group 31's to gain storage room under the pass seat. Even with that, I can start the truck at 0F with no block heater and no starting fluid. If it is just a more=better thing, I get it, and do it also sometimes. Enough said. But if there is a specific reason, I'm interested in learning that too. I watched a battery explode once during cranking, and I am just scared to death of them now, and understand why they are always encased in a steel somehow. For me, less is better, down to what you need. BJS, your lower additional bracket looks great. Nice work on that. I am doing the same to add a serpentine driven A/C compressor to my 925A2 (8.3L) with a cab roof evaporator (Red Dot).
Ah. For some reason I had it in my head that the stock alternator was 100 ampsThe stock alternator is rated at 60 amps, and spits out about 62 amps even at idle. A 45 amp load is ok, but the pivoting point would be how long you intend to run the load. The stock alternator has terrible cooling, especially at idle. Due to that point only, it really becomes the question. Just momentarily or even a few minutes at a time, probably ok. If continuously on for an extended long idle, your stock alternator may commit suicide. It may tolerate it if you raise the idle speed with the hand throttle when the load is on, not sure if that fits with what the load is or what you are doing with it.
Good to know. And yeah, as long as it puts out 60A or so at idle I should be fine. I really have nothing else that draws a lot of power.. Headlights are LED, so they're not a problem.It does. It has twin internal fans and is built with high quality materials. It develops 177 amps at engine speed and room temp. I have yet to grab an idle output measurement of it. I've had 2 so far, but people hunt them down and get them from me before I can install one on my own vehicle!
Yup. TruckLite LED headlights. Best mod that I have done so far.. They are REALLY freakin brightOh wow, your headlights are LED? Was that a conversion you did yourself?
