M923A2 Compressor Noise
Elijah95
Certified Rookie
1,240
1,215
Georgia
Some A2 fans operate without air pressure to them. Some operate with air. It depends on the type of clutch brand it has.
In that case, we need documentation of both so I can edit, and maybe make a sticky
charlesmann
713
Temple, Tx
Please note the capitalized words are not yelling, it’s to break up the large paragraphs and emphasize.
thanks. ill looks further when i get off my hitch.
why would one think you are yelling? doesn't everyone know CAPS is to denote a significant phrase, word or so forth, so as to not misunderstand, miss it or whatever?
Elijah95
Certified Rookie
1,240
1,215
Georgia
Since caps is generally yelling in the internet world, sometimes folks think I’m yelling
simp5782
Feo, Fuerte y Formal
9,502
Mason, TN
Any way to tell by looking at them?
Nope. If it comes on when the air tanks are empty then its a NO shutterstat.
The m915 series trucks share the same NO shutterstat 1047-36000-30 as some m939A2s
charlesmann
713
Temple, Tx
you know what they say, "thought nit, thought he farted but he @#%$". that is bc they are overly sensitive. i sometimes type all caps. I'm blind in 1 eye, can't see out the other, and opposite for hearing, can't hear out of 1 and deaf in the other. i use caps to help me format small font cells and forget to turn it off, then folks on another forum think I'm yelling. i just keep it going then, just to stir the proverbial pot.
but, hey, thanks for the info. that dan actuator is $200, so i'll harvest first then buy new if need be, and rebuild 1. where do you get the packings from? the ipc doesn't show o-rings, and since its a paozz cage code, its a throw away item to begin with.
Elijah95
Certified Rookie
1,240
1,215
Georgia
Good new ones can be had as low as $80 on popular auction sites, and that thread I linked earlier gives info on the rebuild parts to order sir. I can’t dig through at the moment, but if you pay more than $100 for a brand new unit you’re overpaying
fpchief
225
South Alabama
Just let mine get up to temp, brought it back home and let it idle building more heat. Got to 220 and no fan. Reckon I need to rebuild it or replace. I have o-ring sets so will try if rebuilding works first.
Elijah95
Certified Rookie
1,240
1,215
Georgia
Before you tear it down, take a thermal gun and shoot the pipe where that threads in, just to rule out a sensing unit misreading
Elijah95
Certified Rookie
1,240
1,215
Georgia
He is referring to the shutterstat to ensure its reading the correct temp
8.3s have two thermostats
Some do and some don’t, my truck did not and had a 3 or 4 piece housing i can’t remember. Crazy the minor variations
simp5782
9,502
Mason, TN
Yea, but the thermostats could cause the temps to be wrong at the shutter stat correct?
205 thermostat. If its open you will know it.
Temp sensor is on the block down near the lower hose. Shoot that with the temp gun first compared to your gauge
fpchief
225
South Alabama
Yesterday took it out and ran it pretty good. Then idled down my road trying to build heat. Gauge got to around 230 but shooting the area around the sending unit was around 195....I think. Kinda crowded down there. Looks like my gauge may be off alot. I just want the thermostat to open so I can get good heat to upper pipe to check shutterstat.
