Ford Mechanic
- 6
- 38
- Edenton, NC
I just installed some new guages and lights. The guages I bought off Amazon and we're 12 volt. I decided to install a 12 and 24 volt fuse panel were the CTIS valve used to be to make all my wiring easier. I used the CTIS switched power to trigger a relay so I had 12 volts switched on when in run. I also put a 12 volt power point on this relay. The guage pod I hand made.
More to come...
More to come...
