M923A2 Front Axle
shadowdd
College Station, TX
Other than the obvious of taking out the front "propeller" drive shaft... is there a way to rebuild the slip joint. I noticed today that upon coasting to a light or just letting off the fuel pedal for a sec there is a thumping sound. I found out that the front drive shaft is a little loose at the slipjoint. Is this a job for a drive line shop or is this something that can be tackled at home. It has been lubed but the grease slings out after running down the road.
Thanks, Bryan
