m923A2 inflating front axle boots w air question
blmyachtsales
Swansea MA
I searched and read but still have some questions. I assume the passenger hub air seal is leaking allowing air into the knuckle inflate the boot and out the top vent. Question is what else should I do when replacing the air seals? I'm thinking inner and outer axle seals and silicone boots. Anything else? Looks like Boyce has hub seal kits, didn't see a kit at Eriks. Any trick to the operation.
Facts / other symptoms:
Front tires always low as if CTIS is in emergency
rear tires low but not nearly as low as the front (like
CTIS was working fine
does the 5 light flash after sending air out for a while
when I shut the truck off the leaking stops and the tire does not deflate further
Both front tires are low but only the passenger leaks into the boot and out the top vent.
Thanks all
