M923a2 issues starting.
Ttallent13
51
13
Virginia
I’m having issues starting my 1991 m923a2. The truck ran fine about 3 weeks ago. The truck will crank but won’t start. I have a digital voltmeter in the truck. I have 24.4 ish volts before cranking. I notice though that when I flip the starter switch the voltage drops to around 17.4 to 17.6. I don’t remember in the past it dropping that low, I’m not sure what the minimum it needs in order to crank but that seems low. I tested the batteries and they test good but my tester said they were weak. I have them on the charger. Just wanted to see if any other bases need to be covered? Thought I remember reading someplace they need a minimum of 20 volts to turn over, but can’t find that now. Thanks in advance
simp5782
Feo, Fuerte y Formal
9,388
Mason, TN
So it spins over but won't start?
Is the fuel solenoid retracting? Is the manual fuel shut off pulled?
162tcat
46
Washington
Does it turn over at normal speed?
Any smoke from the stack?
What is the outside temp when attempting to start?
Ttallent13
51
13
Virginia
Seems to turn over maybe slightly slower. It was around mid 40’s I even plugged in the block warmer just for the hell of it to see if that makes a difference. Just cranks. Will check more stuff later.
Ttallent13
51
13
Virginia
Haven’t had a chance to work on the truck till this afternoon. At the bleeder screw I’m not getting any fuel I see a few air bubbles when I crack it open and crank over the motor. Im thinking Maybe fuel line might be sucking air
Ttallent13
51
13
Virginia
I’m going to see if I can find a cracked hose or fuel leaking. I’ll try to pressurize the tank this weekend and try checking for leaks. Any other suggestions?
