M923A2 Question about Parking Brake!!!
cselectricsouth
Jacksonville
It turned out to be the override button had been pushed in ....a very large friend (400lb) climbed in the truck & his big backside pushed the button in which I didn't notice or think of LOL
lindsey97
17
wynnewood, oklahoma
Be aware that the failsafe module grounds at it's location with one of the two 7/16" bolts that secures the module to the truck. I had a couple other issues, such as gas gauge acting up, and I had installed new led headlights, so I built a ground harness for the truck. Ran a ground from the headlights, to the ground stud on the starter, then to the failsafe module, then to the fuel sending unit, and finally from the failsafe module to the back of my new volt gauge in the dash panel. There is also a ground strap for the hood at the left corner by the radiator, and another ground strap at the back of the intake manifold, to the cab. Check and clean all of your grounds.
