M923A2 south florida mechanic / tech needed
Fonzzie
South Florida
Hey everyone
First time posting! I have an early 90's M923A2 truck in South Florida that needs some work, primarily on the ABS system air lines. Does anyone know of any mobile technician(s) in South Florida (broward county) that work on these? I found the manuals here on the site which are a great help but would prefer someone with knowledge working on these trucks to go through it.
Cheers
19,060
Hey everyone
Cheers
So, finding a mechanic to work on your M923 might be hard to find and harder to afford - unless you have a wheelbarrow full of money at your disposal. Your new at this but you can learn if you are willing to turn a few wrenches and read a bit. There are threads about servicing the ABS brakes. There is even a tool that plugs into the truck that will tell you if something more than air lines are the problem. The TM's (Technical Manuals) offer troubleshooting guides in flowchart style. The TM's are free to download on the site.
If you really have nothing wrong but air line problems, you need to go to a local "big truck parts" store. Lay your plastic line on the counter and ask for 20 feet or so of it - and replace whatever might be bent, kinked or chewed up. You need to be sure to buy DOT approved plastic line. Don't shortcut that or you might die.
Another thing that is easy to do is look for air leaks anywhere on the truck. With the motor running, all that rattling and fan noise will make it really difficult to hear anything except a really big leak. If you happen to have an air compressor, you can air up the truck without the motor running. CHOCK the wheels on front and back of both sides of the truck. Picture below. (Had to have fun with it!)
If you do have a compressor, pick up a glad hand while you are at the parts house. That will connect your air line on the compressor to the drivers side front glad hand and quietly air up the truck. Crawl around under and inside the truck listening for air leaks. Use a bottle of soapy water if you can't feel the leak. Fix accordingly - and see what happens next.
Welcome to the group.
Don't hesitate to post questions about how to fix things AND most importantly - use your cell phone to take pictures. Pictures before you disassemble something will be your best friend! We love pictures too. Pictures for your "new to you" truck and pictures of a problem area... Both will get attention here!
