M923A2 speedometer broken
juanprado
2,737
Metairie/La (N'awlins)
It is old school mechanical with a cable/casing. Pull the cable off the head and see if it spins? The cable can be replaced and greased or the entire assembly can be replaced. Napa sells just the inner cable with a universal cut to fit & crimp the drive end if the outer sheath is still in good shape.
