M923A2 Transfer Case Issues
Kennyw1981
Robertsdale, AL
Hi all, Im new to this site and these trucks. Ive recently purchased a 1993 Model M923A2 Dump truck and am having transfer case issues. I can only drive the truck foward using the front wheels. I do not have reverse at all and no power to the rear axles. Ive tried every combination I can come up with and no matter what i do I can only go foward using the front wheels. Transmission is fine, the input shaft from the transmission spins as it should in foward and reverse.
Also I'm postive its not the original Transfer Case. The linkage for the High/Low shifter has been modifed to the right side of the truck, the original trasfer case high/low linkage wason the left of the transfer case and the current case is on the right. Odds are I am going to need a new transfer case im sure but im not sure which one i have, the numbers i find on it bring up a couple different ones. I dont mind going back to the original one but not sure what the original one was. 5875E317 is the one in it and has an overhaule date of 4/82 which is much older than the truck.
Any help/Info would be greatly appreciated. I attached a couple pictures of the transfer case. Thanks
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
T138 transfer case and parts are available to rebuild it or replace it. I might have one laying around here somewhere. You can bust it open and try to source the parts thru ebay or surplus dealer or just replace it. Someone did that cause it was cheaper and more reliable than the T1138 case and they did not need the overdrive. More than likely it is a busted output shaft
The front axle output shaft slips inside the rear axle output shaft with its splines. The front axle output has the gear on it that is spun by the intermediate shaft in the case. More than likely the output shaft for the rear axle is stripped or the output for the front axle has taken all its splines off.
7346771 is the front axle output found on ebay.
8332554 is the rear output shaft found on ebay. For the cost of both of those might be cheaper to source a busted case or just find a whole one to replace it.
Member CSMDavis has the original T1138 transfer cases over in Hattiesburg, MS for $1700.
Kennyw1981
Robertsdale, AL
Thanks for the reply, I'm definitely leaning more towards just replacing it. Quicker I can get it up and going the better, I have a good bit of dirt I need to move with it. If you have a good one laying around how much could you let it go for?
simp5782
9,339
Mason, TN
I think i sold my last one for $800. I will check around, I think i still have one left. I know I sent one to NM and one to Florida last month but I believe I have another left..... I reached out to CSM Davis in Hattiesburg so maybe he has one closer to you.
You may also message member RyanAruba he is near you in Panama City and has some 5 ton parts.
